2000 Honda Civic tach wire?
f00dstamps
Copper - Posts: 132
Posted: March 12, 2006 at 8:04 PM / IP Logged
i just installed a Compustar with the CM3000 brain. i put it in tach sense mode and it will not learn the tach. i get 3 chirps and 3 parking light flashes. the manual says that i have the wrong tach wire. i measured this wire at the brain and it measures ~3VAC. when i give it gas, the voltage changes with the RPM. without this working correctly, i cannot put it into reservation mode.
i tried it in voltage sense mode and i can get it to go into reservation mode. when i try to remote start, it flashes the parking lights once which means that the engine is already on. i know the engine isn't on.
please help.
EDIT: i took the tach wire at the 2-pin test connector that is located on the driver's side engine bay near the firewall. there is only 1 wire to tap into and is a blue wire. do i have a bad brain?
KarTuneMan
Platinum - Posts: 7,056
Posted: March 12, 2006 at 8:11 PM / IP Logged
The tach wire you need is a blue wire in a blue connector above the fuse box. It's a four cyl. reading
f00dstamps
Copper - Posts: 132
Posted: March 12, 2006 at 8:13 PM / IP Logged
so, don't take the one from the engine bay?
f00dstamps
Copper - Posts: 132
Posted: March 12, 2006 at 11:47 PM / IP Logged
i'm not sure what the problem was but i unplugged the brain for several minutes, plugged it in, and the brain began reading the tach wire correctly. remote start works now. thanks guys.
auex
Platinum - Posts: 5,041
Posted: March 13, 2006 at 10:38 PM / IP Logged
I still like the blue behind the cluster. Easier in my opinion.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
