02 corvette trunk release
carrman
Member - Posts: 16
Posted: March 17, 2006 at 7:33 PM / IP Logged
Im trying to find the right wire for trunk release at BCM. I have light blue, but there are several wires. More than one shows negative when I hit release. Is there a certain amount of negative it should show? any help like row# or pin would be helpful. thanks
Raymond4646
Copper - Posts: 121
Posted: March 17, 2006 at 7:52 PM / IP Logged
12volts
red
ignition harness
Starteryellow + ignition harness
Second Starter
Ignitionpink + ignition harness
Second Ignition
Third Ignition
Accessoryorange + ignition harness
Second Accessorybrown + ignition harness
Keysense
Power LockRED / black - driver door module in door
Power UnlockORANGE / black - driver door module in door
Lock Motor
Unlock Motor
Parking Lights+brown + headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Triggergray/black (D), BLACK/ white(P) - BCM
Dome Supervision
Trunk/Hatch PinRED / black - BCM
Hood Pinpink/black - BCM
Trunk/Hatch Releaselt. blue - BCM
Power Sliding Door
Factory Alarm Armarms with lock
Factory Alarm Disarmlt. green - driver door module in door
Disarm No Unlock
Tachometerwhite ac cluster or PCM, red plug, pin 10
Wait to startN/A
Brake Wirewhite + brake pedal switch
Parking Brake
Horn Triggerblack - BCM
Memory Seat 1
Memory Seat 2
Memory Seat 3
Raymond4646
Copper - Posts: 121
Posted: March 17, 2006 at 7:59 PM / IP Logged
If no one chimes in with the correct pin then, you must go thru and cut one wire at a time to find it.  Just guess right the first time. LOL
NowYaKnow
Gold - Posts: 1,217
Posted: March 17, 2006 at 11:41 PM / IP Logged
B7-B8 Not Used
B9 LT BLU Trunk Release Relay Output - Coil
B10 BLK Horn Relay Output - Coil
As far as I can see the BCM should have 3 plugs. A 24 pin, 32 pin, and 16 pin. The wire you want is in the 24 pin. It should be the ONLY light blue wire in that 24 pin connector. The 32 pin connector should have 2 light blue wires, that you don't want. The 16 pin shouldn't have any light blue wires. Of course test to be sure, but it looks like the pin above is the one you want. I listed some of the other pins near it so it's easier to pick out. If any of this doesn't seem to go with what you are dealing with post back and I will check again. Hope it helps,
Mike
carrman
Member - Posts: 16
Posted: March 18, 2006 at 8:41 AM / IP Logged
Thanks for the replies, on my next day off I'll try it again.
