Octane R15 Review?
lukeyn
Member - Posts: 47
Posted: March 26, 2006 at 5:58 PM / IP Logged
I just ordered a Phoenix Gold OctaneR15 have anyone had this sub or have heard it play? Please give your input...Thanks~!
sprawl85
Copper - Posts: 204
Posted: March 27, 2006 at 7:45 AM / IP Logged
I wasn't going to post anything because it didn't really have to do with the sub, but since no one is giving you any love hehe... I had a pair of the octane R 4x6's and they sounded like garbage.  Comparable to blaupunkt or sony's cheapest lines.  So I would assume the subs are the same way.  What kinda price can you get them for, maybe I could recommend something a little better.
fiberglass reminds me of peanut brittle... but fiberglass tastes better!
lukeyn
Member - Posts: 47
Posted: March 27, 2006 at 12:25 PM / IP Logged
Well I gave 50 bucks for it off the net...I just needed a sub to play in a 1.2 cubic foot enclosure and this was the cheapest I could find....I have an Mtx 15 4500 sitting at the house that i was going to put in there but it requires a much larger enclosure...Would Polyfill make enough difference So I could still use the mtx 4500?
stevdart
Platinum - Posts: 5,816
Posted: March 27, 2006 at 1:19 PM / IP Logged
No, that wouldn't make up the difference you need.  You would lose a lot of low end response.  In fact, you're not going to get anything better in that box with the 15" PG sub either.  Time to build a new box.
lukeyn
Member - Posts: 47
Posted: March 28, 2006 at 10:50 AM / IP Logged
On Phoenix gold's website they call for a 1cubicfoot enclosure for their sealed spl box with that sub.I was just wondering if this sub will hit loud and as low as a 12 would in this enclosure...
DYohn
Platinum - Posts: 10,741
Posted: March 28, 2006 at 11:09 AM / IP Logged
I tried to look up an Octane 15 but cannot find any info on it.  Their web site indicates they never made such an animal.  Regardless, I highly doubt you are going to find a suitable 15" speaker for that small an enclosure.  Adapt it for a 12" (make an MDF mounting ring) or build a new enclosure.  Sorry.
lukeyn
Member - Posts: 47
Posted: March 28, 2006 at 12:00 PM / IP Logged
Octane-R15 Subwoofer
Mounting Depth . . . . . . . . . . . . . . . . . . .. . . . . 7 1/2 in (190.5mm)
Mounting Diameter . . . . . . . . . . . . . . . . . . .  . . 13 3/4 in (349.25mm)
Overall Diameter . . . . . . . . . . . . . . . . . . . .  . . 15 1/4 in (387.4mm)
Peak Power Handling. . . . . . . . . . . . . . . . . . .  . . . . . . . 800 Watts
RMS Power Handling . . . . . . . . . . . . . . . . . . .  . . . . . . . 400 Watts
Vdd (Driver Displacement) . . . . . . . . . . . . . . . .  . . . . 0.19ft3 (5.4L)
Octane-R15
T/S Parameters
Fs . . . . . . . . . . . . . . . . . . . . . . . . . . . .  . 27.84 Hz
Re . . . . . . . . . . . . . . . . . . . . . . . . . . . .. . 4.14 Ohms
Qms . . . . . . . . . . . . . . . . . . . . . . . . .. . . . .. . .6.18
Qes . . . . . . . . . . . . . . . . . . . . . . . . . . . .  .  . .0.60
Qts . . . . . . . . . . . . . . . . . . . . . . . . . . ..  . . . .0.55
Vas . . . . . . . . . . . . . . . . . . . . . . . . . . . 153.26 liters
Mms . . . . . . . . . . . . . . . . . . . . . . . .. . .  . 206.06 grams
Cms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 159 uM/Newton
BL . . . . . . . . . . . . . . . . . . . .. . . . . . . . . 15.72 Tesla-M
SPL (efficiency) . . . . . . . . . . . . . . . . . . . . . . . . . . 91 dB
Sd . . . . . . . . . . . . . . . . . . . . . . . . .  . . . . 829.58 sq cm
Xmax (field) . . . . . . . . . . . . . . . . . . . . . . . . . 28mm p-p
lukeyn
Member - Posts: 47
Posted: March 28, 2006 at 12:06 PM / IP Logged
http://www.phoenixgold.com/2004/techsupport.html
go here, then scroll down to bottom and click manuals, then a page will load up, go to speaker, then octaneR, then woofer, then R15woofermanualweb.pdf
Thanks for the help man I appriciate the knowledge.
Btw how do you edit posts, once you have them sent?
DYohn
Posted: March 28, 2006 at 12:28 PM / IP Logged
OK, if you put that speaker into a 1 cuft sealed enclosure, you end up with a real nasty peaked response with fb at 70Hz and f3 at 50Hz.  This will sound like a boom box and have little to no deep bass response.  (If you don't understand terms like fb or f3, click on the "Thiele-Small" link on the left side of the forum.)  Put it into a 3cuft sealed enclosure and you end up with a much smoother response curve, fb at 46Hz and f3 at 35Hz.  3cuft is a much more common enclosure size for a 15" woofer.
lukeyn
Member - Posts: 47
Posted: March 28, 2006 at 9:40 PM / IP Logged
I have a question then...Why would they post of on their site that the correct box size for an spl box is 1cu ft.
Im not doubting you in any way or trying to be a smart ass...I was just wondering?
