2003 Tahoe Security Light
jae-rome
Member - Posts: 25
Posted: March 28, 2006 at 2:33 PM / IP Logged
Hey all,
I installed a CLifford RSX 3.5 and used the 457g however when I start the car with the key the security light stays on, when I remote start the vehicle the security light goes off. I left the key in the ignition for a half hour with no luck I even tried using the 555L and still no luck any information would be helpful
mo12v
Posted: March 28, 2006 at 2:56 PM / IP Logged
Did you cut any of your Ignition wires in half to hook up Remote Start?
MO
redpeppers
Silver - Posts: 483
Posted: March 28, 2006 at 11:03 PM / IP Logged
sounds like you have the 457g hooked up wrong.....we need to know how you wired it up before we can help......
Where theres is a wire there's a way.
jae-rome
Member - Posts: 25
Posted: March 28, 2006 at 11:58 PM / IP Logged
Ignition wires are not cut, just tapped into. The only cut wires is the starter wire. The 457g is hooked up:
Black - Ground
Red - 12 Volts
Gray/Black - Not Used
RED / White - Not Used
BROWN / White - Not Used
Light Green - Lock Input From Alarm
Blue - Unlock Input From Alarm
Blue/White - Status Wire From ALarm
Green - Door Triggers
3 Pin Harness Not Used
Again if the 457g was not hooked up correctly then remote start would not work at all should just crank but not turn over. The car remote starts correctly as it should with no problems the problem lies when I start the car with the key the security light goes on.
Thanks for the help
cntrylvr79
Silver - Posts: 582
Posted: March 29, 2006 at 12:26 AM / IP Logged
TRy putting a diode on the ground of the 457 with the stripe side facing away from the 457.  Then reprogram the 457.  HAve had that happen a couple times with older 457s.
Cause I'm So white and nerdy...
First Class Certi-fried installer
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
