04 chevy remote start
nattopdog
Member - Posts: 13
Posted: April 04, 2006 at 6:23 PM / IP Logged
We are installing remote start and alarm keyless on an 04 chevy truck. we have got the bypass module i believe the number is a 457g it is a directed product. Anyways we have the alarm and keyless working. But it tells us to locate the passkey box to find the pink wire. Well i can not find the pass key box. there is a pink wire in the ignition harness but i do not want to cut anything before i am certain. Also what is this i hear that you have to have a third ignition to keep the transmission from messing up??? any help on either problem would be apprecitated.
JWorm
Platinum - Posts: 2,208
Posted: April 04, 2006 at 7:06 PM / IP Logged
Did you miss the note in the instructions about the 3-pin harness only being used on certain Passkey 3 vehicles? Your truck has Passlock 2. The 3 pin harness is not used. The only wire from the 457G that gets connected is the data wire. Gets connected to the purple wire in the OBDII plug.
mo12v
Posted: April 04, 2006 at 7:12 PM / IP Logged
You shouldn't need the 3 PIN Harness.
This is how I wire Chev P.U.s
Some use the ORANGE as Accessory
Constant 12 voltsRED OR RED / WHITEIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Ignition #2WHITEIGNITION SWITCH HARNESS
Ignition #3ORANGEIGNITION SWITCH HARNESS
AccessoryBROWNIGNITION SWITCH HARNESS
MO
