panic button for window automation?
s2kman
Posted: April 07, 2006 at 2:02 AM / IP Logged
I have a Hornet 727t alarm which I'm adding to my keyless entry remote, I'm also planning on adding the window automation module and was wondering if it was possible to use the panic button as an auxiliary channel since my keyless entry remote only has a lock,unlock rear window roll down button and the panic button(which I care less for). Has anyone done this before as I'm thinking it might not be possible cause the panic button puts out intermittent honks?
doibuy
Copper - Posts: 177
Posted: April 07, 2006 at 11:34 PM / IP Logged
There isn't a wire on your alarm that is a "panic" wire, so to my knowledge this wouldn't work.  The windows will roll up when you arm the system, the only reason for hooking up the aux channel is to vent/roll them down.
s2kman
Posted: April 08, 2006 at 1:26 PM / IP Logged
When I lock the doors, the windows will roll up, i just need to use the panic as an auxiliary cause I'm using stock remote. I figure I'm going to have to use about three relays, one relay wired to the ignition so the windows can only be vented when the ignitions off, another relay I'm guessing is for a pulse to steady output to put out a constant output to the horn wire(which will be bypassed to vent/roll windows), then theres the third relay which is to convert the + output to - input(window modules aux input is (-). Now I'll just have to tie them all together and test if it works.
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
