95 Mustang, Black Widow 4150
longfellowdeeds
Posted: April 23, 2006 at 5:45 PM / IP Logged
hi, i am installing a black widow 4150 (alarm+ keyless entry) in my 95 mustang, this car has power locks but no keyless entry!, i need someone to walk me through installing it, i have the wires connected but all i hear is the relay's in the brain clicking! PLEASE HELP!!!
mo12v
Posted: April 23, 2006 at 7:17 PM / IP Logged
If you are sure your Mustang came WITHOUT Factory Keyless, then you will need to do a 5 wire Reversal.
Does your Unit have ON-Board relays??
Find your LOCK & UNLOCK wires ( PINK / Yellow & PINK / Green ) Kick Panel
Cut them in Half.
One side of cut wires will have 12 Volts when you Press the DRIVER Door Switch.  ( this will be called Switch Side )
One side of cut wires  will show Nothing ( this will be called Motor Side )
5 Wire Reversal:
? = your Unit wires if you have ON-Board relays
Lock:
? = Switch Side ( N / C )
 ? = Motor Side ( COM )
 ? = 12 Volts Constant ( N / O )
Unlock:
MO
longfellowdeeds
Posted: April 23, 2006 at 7:47 PM / IP Logged
ok, that helps me out with the locks, but why won't the unit act properly? all i get is click noise from the brain.
mo12v
Posted: April 23, 2006 at 8:38 PM / IP Logged
Not sure of your question??
Are you asking about the whole Alarm working "properly"? or the Door Locks??
MO
longfellowdeeds
Posted: April 23, 2006 at 10:46 PM / IP Logged
the whole alarm, i have all the wires except the door locks connected, and all the alarm does is makes a click noise and the alarm goes non-stop. why would the the brain make the clicking noise non-stop and the alarm go off non stop???  what do you have to do to get these alarms to work ???
mo12v
Posted: April 24, 2006 at 8:18 AM / IP Logged
If you are sure you have everything connected properly..........
Be sure the Alarm is NOT in Valet Mode.
Also, how long after Arming, does the Alarm Trigger??
MO
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
