Weird feedback from RS in stereo
mustangfoo
Silver - Posts: 371
Posted: April 30, 2006 at 2:24 AM / IP Logged
hey guys, I have recently had a weird noise pop up in my stereo system.  The noise is not a pop, but more of a long louder noise that fades.  It happens when I RS and when I get in the car, if I put my HU face on first and then turn the key into on, and step on the brake to turn RS off THATS when it makes the noise.  It is really weird, either it never did it before or I never noticed it.  If anybody can help me out I would appreciate it.
Platinum - Posts: 12,488
Posted: April 30, 2006 at 10:18 AM / IP Logged
Try using a different ignition wire at the stereo or a different constant power wire. If you want you can also use a relay to filter out the ignition wire by wiring it so you can get a better ignition source from the battery.
85: GROUND
86: IGNITION wire from radio
87: Constant power wire from battery or ignition switch
30: To IGNITION wire on the radio
87a: NOT USED
This relay will give you a solid and undiluted switched power source.
mustangfoo
Silver - Posts: 371
Posted: April 30, 2006 at 8:38 PM / IP Logged
interesting, yea I had changed the acc wire from the HU cause I thought it might fix it, but nope. I do have an extra relay here sitting next to my hand, so maybe I will try that.  Thanks a lot.  Any other ideas guys before I dig into wiring again???
mustangfoo
Silver - Posts: 371
Posted: May 02, 2006 at 4:37 PM / IP Logged
no other suggestions guys???  If not today I will try the relay. . . .
