15 Treo 4 Ohm DVC Wiring
rboutin2
Copper - Posts: 90
Posted: May 10, 2006 at 9:53 AM / IP Logged
I need to know how to wire my 15" 4 ohm DVC treos to ym rockford amp, and still have the amp bridged. I got two rockford 450S amps (one for each treo), and they can't be bridged at 2 0hms. The diagram from the12volt says that if i wire them in series they will present an 8 ohm load to the amp. It also says that it will work on an amp that is stable at 4, 2, or 1 ohm mono. My amp is stable at 4 ohm mono, so should I wire the Voice coils in series?
haemphyst
Platinum - Posts: 5,054
Posted: May 10, 2006 at 10:37 AM / IP Logged
Yep. That's all ya got. Wire 'em in series for 8 ohms, and bridge the amp, presenting 4 ohms per channel.
rboutin2
Copper - Posts: 90
Posted: May 10, 2006 at 10:47 AM / IP Logged
I made my question a little more complicated than it should have been. I meant:
i am going to be running one sub for each amp, and they are two channel amps. stable bridged at 4 ohms. would i be able to run an 8 ohm load on the amp when it is bridged?
haemphyst
Posted: May 10, 2006 at 10:50 AM / IP Logged
Yes. 8 ohms, connected to a bridged amp, is the SAME thing, electrically, as 4 ohms per channel. This is perfectly safe to do.
rboutin2
Copper - Posts: 90
Posted: May 10, 2006 at 10:57 AM / IP Logged
Thank you very much! That cleared up a lot of confusion.
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
