valet 712T keyless entry, 1992 accord
estein55
Posted: May 13, 2006 at 9:49 PM / IP Logged
I am trying to install a valet 712T remote keyless entry system on a 1992 honda accord. The car has power door locks, and I have located the power door lock/unlock (BLACK/ white, BLACK/ red) wires under the carpet below the drivers kick panel. I do not know which wires on the valet system to connect to the cars lock/unlock wires. Please help.
cntrylvr79
Silver - Posts: 582
Posted: May 13, 2006 at 10:11 PM / IP Logged
Both violet and violet/black go to ground,  the blue/black goes to the unlock wire and GREEN/ black goes to the lock wire.  The BROWN / black and WHITE/ black wires are not needed.
Cause I'm So white and nerdy...
First Class Certi-fried installer
estein55
Posted: May 13, 2006 at 11:19 PM / IP Logged
Thanks for the help. The door locks are working. My air/heat lights flash when the valet arms/disarms, is this normal?
cntrylvr79
Silver - Posts: 582
Posted: May 14, 2006 at 6:29 PM / IP Logged
Yes it is.  They are all tied into the same circuit that the parkinglight trigger is on.  IT's not a big deal.
estein55
Posted: May 14, 2006 at 9:46 PM / IP Logged
Thanks again. The Heater fan also comes on momentarily (if the fan switch is on) when arming/disarming. It seems weird, but I’ll get over it.
Your help is appreciated very much.
Ethan
cntrylvr79
Silver - Posts: 582
Posted: May 14, 2006 at 11:21 PM / IP Logged
The heater fan coming on is definately a strange thing to be coming on.  Does anything else come on when arming or disarming?
estein55
Posted: May 15, 2006 at 12:08 AM / IP Logged
The heater fan and lights on the heat/air buttons are the only things that come on. I only have the door locks hooked up to the valet, no lights or horn.
