Is it dangerous to go w/ 16 volt HO alt.?
Aruman
Silver - Posts: 363
Posted: May 14, 2006 at 7:07 PM / IP Logged
Hi guys, i'm planning to buy an HO Alt. and i'm thinking of Ohio Gen, and i was talking with my dealer and he told me that he want to check with Ohio if they can make a HO Alt. that can suply 16 volt. my question is, is it a good idea to go with 16volt for daily or can it damage my amps and my car electrical parts? or can a car handle more that 14.4 volt? what's the maximum volt a car can handle? i have a Toyota Corolla. so guys should it be a good idea or not, will 16 volt be dangerous? thnx guys, Aruman.
Shaking The Neighborhood
323gtx
Member - Posts: 12
Posted: May 14, 2006 at 9:15 PM / IP Logged
My advice would be to run your amps off of the 16 volt and keep your factory alt. running "normal" car needs. I am using a 16 volt, 300 amp in my Izusu Rodeo. It is ran to three amps, two batteries,  my winch, and aux. lights. Everything else on the truck runs off the factory alt.
Mazda 323 GTX +
330 lbs. glass +
4, 5 gallon buckets resin +
1600w RMS @ 1ohm = 162.3db
jeffchilcott
Platinum - Posts: 2,483
Posted: May 14, 2006 at 11:40 PM / IP Logged
why are you planning on running 16volt?    do you have betterys that will handle this type of voltage, a standrd 12 volt battery wil fail very very quickly if charged by a 16 volt system
That is my first question on why you want to run 16 volt?
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
forbidden
Platinum - Posts: 5,354
Posted: May 14, 2006 at 11:58 PM / IP Logged
And how do you think the vehicles computers are going to react to it.....I smell smoke from burned circuits.
KarTuneMan
Platinum - Posts: 7,056
Posted: May 15, 2006 at 12:47 AM / IP Logged
I love the smell of smoke in the morning.....
Audio Force make a 16 volt battery just for this application. (from the makers of Kinetic)
Same size as the 2400....$499.00
