Relay for keyless entry
airmcn_3
Posted: June 20, 2006 at 11:15 PM / IP Logged
I am trying to find out a few things.  Mostly how to correctly wire a relay.
I have two wires comming from the brain of my alarm, One way to wire it is to have it throw a - signal to both lock and unlock.  you can also wire it so that it has +signal.  The problem I am running into is that neither the -signal or the + signal are strong enough to trigger the locks.   My question is how do you properly wire up the relays to boost either + signal or -signal?  I would appreciate both diagrams if possible.
Thanks for your hlep.
Chris
duct tape
Copper - Posts: 125
Posted: June 20, 2006 at 11:39 PM / IP Logged
if you want to wire for negative door locks you would connect
pin 87 to ground
pin 86 to 12 volts
pin 85 to the negative trigger of the keyless unit
pin 30 to your door lock/unlock wire
if you have positive locks, you wire the relays the same, except pin 87 would be wired to 12 volts.
airmcn_3
Posted: June 21, 2006 at 8:06 AM / IP Logged
Dude you rock!!  Thank you for your time!
Chris
carrfamilynj
Member - Posts: 11
Posted: June 25, 2006 at 8:37 PM / IP Logged
You stated "pin 85 to the negative trigger of the keyless unit"-would that be the lock trigger or the unlock trigger?
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
