Pioneer Premier Changer Error
Fosgate3
Copper - Posts: 328
Posted: June 24, 2006 at 1:52 PM / IP Logged
I've connected a Pioneer Premier CDX-P2000 CD Changer to my DEH-860MP head unit and I am getting an error message, "Error 60". Can anyone tell me what this code means?
Thanks in advance...
duct tape
Copper - Posts: 125
Posted: June 24, 2006 at 2:30 PM / IP Logged
error 60 means that you have a electrical or mechanical fault.
pioneers website says to turn off ignition, then back on.   you probably tried that already.  i would check all connections, make sure you dont have any bent pins on the connectors.   you might have a bad changer though.
Fosgate3
Copper - Posts: 328
Posted: June 26, 2006 at 6:54 PM / IP Logged
would the horizontal/vertical settings on the side of the changer cause such an error?
geepherder
Platinum - Posts: 3,668
Posted: June 26, 2006 at 8:25 PM / IP Logged
If set wrong, they could cause the changer to skip more, but shouldn't give you an error message.
Tuesday, July 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
