alarm/remote start 2005 corolla?
cml0101
Member - Posts: 8
Posted: June 25, 2006 at 12:31 PM / IP Logged
im having a problem disarming the the factory alarm on a 2005 corolla. it says to use the status output on the blu/blk wire on the ignition harness to disarm but whn i use it it still doesnt start without the key.. can anyone help please?
cml
cml0101
Member - Posts: 8
Posted: June 25, 2006 at 12:37 PM / IP Logged
i was told to use the status output to disarm the factory alarm while remote starting but when i use it does nothing but crank the engine. it say to plugin to the keysense blu/blk on the ignition harness. can anyone tell me why this isnt working
cml
KarTuneMan
Platinum - Posts: 7,056
Posted: June 25, 2006 at 12:54 PM / IP Logged
My notes say to pulse the "unlock" wire to disarm. What type of imobilizer bypass are you using?
cml0101
Member - Posts: 8
Posted: June 25, 2006 at 12:56 PM / IP Logged
not using ay bypass.
cml
cml0101
Member - Posts: 8
Posted: June 25, 2006 at 12:58 PM / IP Logged
it didnt say to use a bypass it just said to connect the status output to the keysense wire
cml
jhull
Member - Posts: 17
Posted: June 25, 2006 at 1:26 PM / IP Logged
sounds like you might have a chip in the key...
if it starts when you put the key in the cylinder and doesnt start without the key in the cylinder it will need a bypass. directed part number 556u will work, but you are going to loss a key.
jhull
Member - Posts: 17
Posted: June 25, 2006 at 1:27 PM / IP Logged
I posted on your other topic...
sounds like you have a chip in the key use directed part number 556u
cml0101
Member - Posts: 8
Posted: June 25, 2006 at 1:33 PM / IP Logged
what abou tthe 555u
cml
jhull
Member - Posts: 17
Posted: June 25, 2006 at 2:49 PM / IP Logged
yeah that will work as well, thats just last years part number, basicly the same as the 556u
cml0101
Member - Posts: 8
Posted: June 25, 2006 at 3:05 PM / IP Logged
thanks
cml
