commando RS-560 on 88 Camaro
eagerinsight
Member - Posts: 20
Posted: July 01, 2006 at 12:06 PM / IP Logged
Just purchased a commando rs-560 and installed all of the alarm and power lock features. Alarm and power locks work great, but when I installed the remote start feature I get nothing? I installed the wiring for the starter output, two 12v inputs, ignition output 1, there is no ignition output 2, and the heater/acc output.  I haven't installed anything for the tach signal, brake switch out door pin triggers. When I press start on the remote nothing happens? Do I need to install the other wires, I was told it should start without installing the other wires yet. I tested the wire from the module to the starter output and when I press the start button I don't see any voltage? Any suggestions?
KarTuneMan
Platinum - Posts: 7,056
Posted: July 01, 2006 at 4:16 PM / IP Logged
Is you car an auto trans? Yes you need the brake and tach....
eagerinsight
Member - Posts: 20
Posted: July 01, 2006 at 6:06 PM / IP Logged
Yes its auto trans, so it won't work until i hook up the brake and tach?
mobilesndfx
Copper - Posts: 49
Posted: July 01, 2006 at 6:16 PM / IP Logged
Yes, you need brake and tach both hooked up. Brake is easy, tach could take some experimenting depending on your alarm and car.
Alpine 9835, MB Quart components, (3) JL Audio 10w3v2, JL Audio 500/1, JL Audio 300/4, Streetwires wiring
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
