Ohm Conversion
adg-audio
Posted: July 05, 2006 at 1:44 PM / IP Logged
My Home stereo has a 6 ohm outlet and I have an 8 ohmRockford Fosgate 8" sub in a bazooka tube.
Now my question:
Is it safe hooking the Subwoofer directly to the stereo?
or
How would i go about/ what I use to in order to make it safe and correct?  In essence, How do I convert ohms and ohm loads?
jeffchilcott
Platinum - Posts: 2,483
Posted: July 05, 2006 at 2:42 PM / IP Logged
yes you will be fine.   The amp is rated with a minimum of a 6 ohm load.       running a higher load will not hurt anything, it will just make slightly less power.
I cant sya it will sound the bast but you can try it.
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
adg-audio
Posted: July 05, 2006 at 4:19 PM / IP Logged
Sounds good
Did it while I was at Lunch and it sounds good it could use a filter of sorts to block out all the mid-bass and highs.
How would I make something of that nature?
and I'd still like to know how to covert ohm:  I.E. 4-6,  8-6, etc?
Thanks again
jeffchilcott
Posted: July 05, 2006 at 4:24 PM / IP Logged
the only way to alter impedance to to use speakers as an additional load.
I believe thier is a sticky topic at the top on designing crossovers, read that on how to block out the frequencys you dont want
2007 World Record
