what wattage resistor
mrcllusb
Copper - Posts: 489
Posted: July 09, 2006 at 5:24 PM / IP Logged
I need to add resistors for my lock unlock hook up with my clifford arrow alarm.Do i use 1/2 watt or 1 watt resistors?
"ole blake"
bmwpwner
Copper - Posts: 174
Posted: July 09, 2006 at 5:54 PM / IP Logged
i use 1/2 watt resistors and have for years. to be honest i'm not sure what the difference is though. i really should do some searching on that. but for sure 1/2 watt will work. good luck and hope this helps.
"I cannot teach anybody anything, I can only make them think."
-Socrates-
meltingplastic
Copper - Posts: 225
Posted: July 10, 2006 at 7:43 PM / IP Logged
if you dont know what difference between different wattage resistors is.. im quite scared..
yes half wat will work fine.. most remote start systems put out mAs so u dont have to worry about them overheating and blowing them
Driving a Bagged, Caddied 02 s10
bmwpwner
Copper - Posts: 174
Posted: July 10, 2006 at 10:18 PM / IP Logged
so what is the difference? i have never claimed to know everything and i'm always willing to learn.
-Socrates-
meltingplastic
Copper - Posts: 225
Posted: July 11, 2006 at 12:13 PM / IP Logged
the wattage means how much power through the resistor it can handle before it blows.. like if u have a 1 watt resistor.. take the current output and multiply it by the voltage through it.. so typically in car its 12v(or 14.4 u wanna be more exact) and most outputs in alarms are like 500mA so uve got (12)*(0.5A) = 6 watts. now even though your going over the wattage its not long enough for it to blow the resistor due to it not being on that long. i dont remember how long there is until itll blow but basically it heats up and burns..
meltingplastic
Copper - Posts: 225
Posted: July 11, 2006 at 8:49 PM / IP Logged
well the main reason i need to know about the power rating of resistors is cause im going to school for electronics engineering and am in an Analog Electronics class and we build power s upplies and amplifiers and if our load resistors recieve a power greatre then their spec'd wattage we have to split the load into multiple resistances as to not blow them
texxasaudio
Posted: July 11, 2006 at 9:31 PM / IP Logged
when you split the load in varios resistors also you are bringing the wattege capacity up
texxasaudio
meltingplastic
Copper - Posts: 225
Posted: July 11, 2006 at 11:29 PM / IP Logged
bingo! simple KCL!
dualsport
Silver - Posts: 983
Posted: July 12, 2006 at 9:15 AM / IP Logged
About the calculation of the power dissipation from the example, if the resistor is used as a dropping resistor, the voltage across it isn't going to be 12V, so you wouldn't end up with that large a wattage rating.
Being in series, the voltage is decreased by the load (e.g. door lock actuator).
Usually wouldn't have the resistor connected from the source directly to ground in most cases, since that would just be a load, and not too useful, except for power supply testing.
In general, though, using a larger resistor is always safer. Tradeoff is that it just costs more and takes up more space.
meltingplastic
Copper - Posts: 225
Posted: July 12, 2006 at 12:34 PM / IP Logged
yea.. they are voltage dropping resistors i just didnt wanna make the calculations too much lol
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
