Aux output ideas?
captainzab
Silver - Posts: 606
Posted: July 12, 2006 at 5:49 PM / IP Logged
he means use like channel 6 to have your head light turn on for 30sec (or 60, or 90)
got to use a relay, and change over to the timed
mobilecustoms
Silver - Posts: 397
Posted: July 12, 2006 at 8:15 PM / IP Logged
captainzab knows what im talking about. i put a relay to the headlights for a 30 sec latched time output.
mobilecustoms
Silver - Posts: 397
Posted: July 12, 2006 at 8:26 PM / IP Logged
the sky is the limit is absolutely true if you can imagine it it can be done.
cal2vin
Member - Posts: 23
Posted: July 12, 2006 at 9:03 PM / IP Logged
ya i think im def going to do windows (up and down), my musical horn thing if possible, and maybe the headlights deal. How much extra do you think the installer would charge for putting the relays in and hooking all that up to the aux input. BTW what does a relay do?
captainzab
Silver - Posts: 606
Posted: July 12, 2006 at 10:10 PM / IP Logged
straight up, a relay is a switch (on and off thingy)
most are rated at 30a/40a, better than a conventional switch rated at a lower amp. It also doesnt require alot of amp to cause the switch (87 to 30)
price- depends on the place. i could care less, and probably do the relay stuff for free (i usually do when it comes to trunk release)
But the 530T, is different, pain in the butt to run the wire through the door and through the boot. Charge you big!
cal2vin
Member - Posts: 23
Posted: July 13, 2006 at 12:02 AM / IP Logged
They already told me it was st8 up 100 dollars installed extra for the window module on top or 495 for the viper 791xv installed. Am I getting ripped off even though this way I will get the lifetime warranty. I can get one on ebay for 200 bucks. Is it really worth the extra 300 for install and warranty?
warmuth_5
Member - Posts: 7
Posted: July 13, 2006 at 2:09 AM / IP Logged
We did actuators to release the tailgate. It was on an 05 titan that had airshocks to make it not drop down abruptly. It was pretty cool to roll up to home depot and pop the tailgate...
No, I will not give you all parts and labor free!
cal2vin
Member - Posts: 23
Posted: July 13, 2006 at 11:19 AM / IP Logged
Thats pretty cool I'm not sure that I would really need that but its still cool
cal2vin
Member - Posts: 23
Posted: July 13, 2006 at 3:36 PM / IP Logged
Ya I thought that sounded good but how about the actual viper 791XV is 495 installed worth it or not?
