12 volt switched power
dudeextrem
Posted: July 15, 2006 at 12:19 PM / IP Logged
I need help locating a 12 volt switched power source for my new stereo, can anyone help w/ this? Thanks
dudextrem
forbidden
Platinum - Posts: 5,354
Posted: July 15, 2006 at 12:22 PM / IP Logged
Sure, it is the wire masquerading as one of the many in your vehicle......more info needed dude. What is the year, make and model of the vehicle please. You might also want to look to the <-------- side of the screen in the blue sidebar under vehicle wiring in the future.
https://www.the12volt.com/installbay/vehicles.asp
jettagli03
Copper - Posts: 311
Posted: July 15, 2006 at 12:27 PM / IP Logged
most cars have extra slots in the fuse box labeled "IGN" or "ACC" that you can easily tap into for a switched source if all else fails.
dudeextrem
Posted: July 15, 2006 at 1:07 PM / IP Logged
ok my vehicle is a 1985 Ford Ranger, and thanks for the help so far, also I am installing a Dual XDM6820 (not sure if that is needed or not) Thanks!!
dudextrem
dudeextrem
Posted: July 15, 2006 at 1:12 PM / IP Logged
ok, i just found the vehicles wiring chart ( https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1983-85&make=Ford&model=Ranger&ID=17840&type=Stereo ) so according to this the switched is the yellow and black wire and the constant is the light green right?
again thanks for the help!!
dudextrem
dudeextrem
Posted: July 15, 2006 at 2:29 PM / IP Logged
sorry for posting alot, but i went into my truck and looked and there is no yellow/bland wire, and 2 light green ones, how do i tell the diff? also there is a grey and yellow wire, would that be it?   THnksa!
dudextrem
geepherder
Platinum - Posts: 3,668
Posted: July 15, 2006 at 7:20 PM / IP Logged
What you should do is test the wires with a multimeter to be sure.  If you don't have one, you can get a cheap one from RadioShack.  Otherwise if you hook something up wrong, you could possibly cause damage to your equipment/vehicle.
Sunday, September 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
