Open Starter Kill on Compustar CM3000
ymboc
Posted: July 18, 2006 at 1:08 PM / IP Logged
Can anyone give me a heads up on how to hook up a normally open starter interrupt?
I'm trying to find a "(-) when disarmed" on the compustar CM3000. I see the "(-) when armed" on pin#5 on connector#1.
Is the only way to get a "(-) when disarmed" to hookup another relay off of that "(-) when armed" output?
dea,can
Copper - Posts: 284
Posted: July 18, 2006 at 5:06 PM / IP Logged
Open Starter Kill on Compustar CM3000 -- posted image.this diagram is from blackwidow so follow the wires from your unit .
dragon
ymboc
Posted: July 18, 2006 at 7:01 PM / IP Logged
Thanks dea,can
Q: does your black widow give a (-) out on the BLACK/ red when disarmed ?
Unless I'm missing something the only alarm status output I see on the compustar is the (-) out when *armed* (I need the opposite)
That being said I'm new to the game so please correct me where I'm wrong
JWorm
Platinum - Posts: 2,208
Posted: July 18, 2006 at 8:01 PM / IP Logged
There is no wire on the Compustar that does what you want.
dea,can
Copper - Posts: 284
Posted: July 18, 2006 at 11:32 PM / IP Logged
u dont have a violet  color wire thats (-) when armed out
dragon
dea,can
Copper - Posts: 284
Posted: July 18, 2006 at 11:33 PM / IP Logged
dragon
JWorm
Posted: July 19, 2006 at 6:51 PM / IP Logged
Do you know what a normally OPEN starter kill is?
If the alarm brain is unplugged, the starter kill stays active. The alarm must be disarmed before a (-) signal is sent to the relay activating it (connecting 30 and 87 together) which allows the car to start.
Old Alpine alarms had this option, and newer DEI systems like the Python 900 have this option. Compustar does not.
ymboc
Posted: July 20, 2006 at 9:30 PM / IP Logged
Thanks for the replys...
as has been stated... the compustar cm3000 doesn't (appear) to have a "(-) when disarmed" output necessary to (easily) achieve a normally open stater kill. Instead it has a "(-) when armed" output.
Is there a workaround to achieve a normally open starter kill on a compustar?
