2004 grand prix alarm/remote start
fosgate2001
Member - Posts: 41
Posted: July 21, 2006 at 2:43 AM / IP Logged
hi just wondering if someone could let me know what wire is the 2nd ignition wire and what pin it is at the bcm if anyone could let me know what color and what pin it is i would greatly appericate it thanks
pmh61
Copper - Posts: 151
Posted: July 21, 2006 at 3:49 AM / IP Logged
12volts      red (50A), red (40A)       +       back of fuse box, passenger dash
Starter      yellow       +       ign harn or BCM, conn. C1, pin 21
Notes: The BCM (Body Control Module) is below the driver side dash to the left of the steering column.
Second Starter      N/A
Ignition      pink       +       ign harn or BCM, conn. C1, pin 22
There are two pink wires in the BCM plug that meter as ignition. To verify that the correct wire is being energized for remote start, slide the key in the ignition key cylinder and then activate remote start. If the key in ignition warning chime comes on, then the correct wire is being energized.
Second Ignition      N/A
Third Ignition      N/A
Accessory      brown       +       ign harn or BCM, conn. C1, pin 23
Second Accessory      N/A
Keysense      lt. green       -       ign harn or BCM, conn. C1, pin 40
Power Lock      RED / black       -       BCM, conn. C2, pin 2
Power Unlock      ORANGE / black       -       BCM, conn. C2, pin 11
Lock Motor      gray       5wi      BCM, conn. C2, pin 52
Unlock Motor      tan       5wi      BCM, conn. C2, pin 46
Parking Lights+      brown       +       front of fuse box, passenger dash
Parking Lights-      BROWN / white       -       BCM, 18 pin plug, pin 8
Hazards      tan       -       BCM, 18 pin plug, pin 16
Turn Signal(L)      use hazards wire
Turn Signal(R)      use hazards wire
Reverse Light      lt. green       +       BCM, conn. C2, pin 42
Door Trigger      see notes       -       BCM, conn. C2
Notes: The driver door trigger is gray/black in pin 26, the front passenger door is BLACK/ white in pin 17, the left rear door is lt. blue/black in pin 7, and the right rear door is lt. GREEN/ black in pin 5. Use all four wires and diode isolate each.
Dome Supervision      gray/black       +       BCM, conn. C1, pin 43
Trunk/Hatch Pin      RED / black       -       BCM, conn. C2, pin 3
Hood Pin      N/A
Trunk/Hatch Release      lt. blue       +       BCM, conn. C2, pin 45
Power Sliding Door      N/A
Factory Alarm Arm      lt. green       -       BCM, conn. C2, pin 22
Factory Alarm Disarm      purple       -       BCM, conn. C2, pin 24
Disarm No Unlock      see factory alarm disarm
Tachometer      white       ac       ignition control module, pin E
Notes: The ignition control module is on top of the engine towards the passenger side.
Wait to start      N/A
Brake Wire      white       +       BCM, conn. C2, pin 30
Parking Brake      ORANGE / black       -       BCM, conn. C2, pin 9
Horn Trigger      brown       -       BCM, 18 pin plug, pin 9
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
PASS-Key III
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes:
