help - no sound!!
phoran
Posted: January 14, 2003 at 1:59 AM / IP Logged
help!!
i am trying to replace an old stereo with a panasonic CQ-RDp212 cd/radio. i have power to the unit, it appears to work, accepts cd's etc. but i can't get any sound out!
anybody brighter than me (not hard) with any solutions?
regards
wvsquirrel
Gold - Posts: 1,237
Posted: January 14, 2003 at 2:08 AM / IP Logged
Need more info...
What kind of car?  Did you use a harness to tie into the existing wires, or did you splice?  Did the existing system have factory amps?  If it did then you'll either need a line converter or re-wire the entire system to bypass them.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
92accord
Member - Posts: 20
Posted: January 14, 2003 at 1:17 PM / IP Logged
i have a jensen 3010x cd player in my 92 accord lx and ive had the similar problem, my cd player will start playing and then all of a sudden the music will fade out or  just cut off and then it will come back on when i like turn on the blinker or  when im diong nothing particular, i can tell the cd player is still playing though, i used a harness to wire it, could that be the problem, should i get a new harness? i already double checked all the connections and they're good. whats wrong?
92hondaaccord
Platinum - Posts: 12,488
Posted: January 14, 2003 at 3:28 PM / IP Logged
Use a different ground other than the one from the OEM plug.
92accord
Member - Posts: 20
Posted: January 14, 2003 at 8:52 PM / IP Logged
ok ill try that, thanks
92hondaaccord
92accord
Member - Posts: 20
Posted: January 26, 2003 at 8:16 PM / IP Logged
alright i ran the ground wire from the head unit to a different ground and it started to work better but its still cutting out, but whenever it cuts out and i turn on the blinker it comes back in. i have no clue whats wrong
92hondaaccord
92accord
Member - Posts: 20
Posted: February 02, 2003 at 10:08 AM / IP Logged
does anyone have any suggestions
92hondaaccord
92accord
Member - Posts: 20
could it be the battery?
92hondaaccord
Posted: February 02, 2003 at 6:24 PM / IP Logged
Try another HU and see if it does the same thing. Ask one of your friends to borrow thier HU and post your results.
92accord
Member - Posts: 20
Posted: February 03, 2003 at 7:23 PM / IP Logged
what's an hu?
92hondaaccord
