Navigation Unit, Integration, Speed Sensor?
F4Pilot
Copper - Posts: 113
Posted: January 14, 2003 at 10:55 AM / IP Logged
Nav is new to me.  Please help.  Did some research on different units.  I keep going back to the two Pioneer units.  One expensive, and the other way expensive.
You CAN connect Nav directly into an existing mobile video system with a display capable of video inputs?  i.e. Sony XAV7W?  Can I connect it to the video input on the existing DVD player?
Speed detector?  Necessary for all units?  Is this reading actual speed or calculated speed based on oem tire size etc.?   I ask because I will be plus-2 size on rims with slightly taller tire profile which effects the actual speedo reading which will throw the Nav calculated position indicator off (is this right?).     Or does the unit recalculate position by GPS frequently and make the correction?
02 Odyssey / 99 F4
Platinum - Posts: 12,488
Posted: January 14, 2003 at 3:37 PM / IP Logged
As long as the source of the video supports RCA inputs ( unbalanced ) then your fine to use the video output of the NAV unit to any video input that supports unbalanced inputs ( RCA ). The speed sense detector wire is a necessity if you want to be able to use the NAV unit and tell you where you are. Tire size difference may not affect your tripmeter as the VSS is run off your ECM from your transmission.
F4Pilot
Copper - Posts: 113
Posted: January 15, 2003 at 10:11 AM / IP Logged
Thanks again Jeff Navigation Unit, Integration, Speed Sensor? -- posted image.
One more...Hope I dont frustrate you on this one...   Have you been on a flight where they show on the movie screen the planes' position on a map relative to the destination?  I would like to have the Nav showing on the rear overhead monitor while still being able to select audio at the head unit.   (Are we there yet? - no, are we there yet? - no, are we there yet? - NO!   type of scenario.)
I could achieve selectable rear-nav-only by using the aux-in on the existing DVD player directly from the Nav unit?  because....
I have the DVD player directly input the rear Overhead monitor (and output the overhead monitor into the indash monitor controller) - to allow front/rear independent viewing/listening regardless of source selected from head unit.
This sounds correct to me.  Would like to make sure.
junior.lx
Posted: January 27, 2003 at 8:47 AM / IP Logged
i have a pioneer navi and i want to put in my truck but i can not find the seed wire for my truck its a lexus lx470 could u email me the diagram pls  thanku
junior.lx
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
