2002 Tundra Factory Alarm Arm?
Silvrefox
Copper - Posts: 126
Posted: August 19, 2006 at 9:19 PM / IP Logged
Did Remote Start and Keyless entry on customer's vehicle today, now customer is angry because he wants his FACTORY security to arm and disarm with his new keyless or he will have it all removed. DEI shows a factory alarm disarm (blue/black in driver's door harness) but no arm wire. Any suggestions???
John
josh1979
Silver - Posts: 320
Posted: August 19, 2006 at 9:30 PM / IP Logged
all i have is dei info too you can call dei see if thay can help im sure his car only had door trigger and if we cant arm it all we need to do is get that to trigger the horn. which unit did you install?
bring back the rotary phone so i dont have to press 1 to proceed in english
Silvrefox
Copper - Posts: 126
Posted: August 19, 2006 at 10:01 PM / IP Logged
dei 561r.
josh1979
Silver - Posts: 320
Posted: August 19, 2006 at 10:23 PM / IP Logged
crap thatunit does not have a ground when armed out put because if it did i had a solution i cant thing of any way to do it with this one dei says the
Factory Alarm Disarm blue/black   -  drivers door harness
i would guess the arm wire is there too. use the factory remote to see if it is arm with remote only or can you arm with the key in the door, if you can arm withe the key there has to be a wier some where in there. but i would call tech support to see if thay have any more info on this. let me know if i can help any more
