2001 malibu amp ground
moosewun
Posted: August 25, 2006 at 5:29 AM / IP Logged
Installing amp in trunk anybody know best place to ground?
What is the problem with grounding back to the battery?
(Got 50ft of 4ga wire why not use it)
oscarnl86
Copper - Posts: 84
Posted: August 25, 2006 at 9:31 AM / IP Logged
you can run it all the way to the battery if you want but i would just ground it in th trunk you can ground it the the schock absorber bolt.
i know some stuff and what i dont know ill make it up feel free to ask
sparkie
Platinum - Posts: 2,061
Posted: August 25, 2006 at 6:51 PM / IP Logged
The best idea is to keep your ground wire as short as possible. The vehicle chassis is a far better to ground to provided you do it correctly. Make sure that the ground wire is the same gauge as the power wire and that you terminate it correctly. Screw or bolt the ground to an area of the chassis that is clean and bare metal. Don't go through a section of the body that the other side is exposed to the outside. It will corrode over time and ruin your ground connection. Attach it to a thick piece of metal. Don't use any existing bolts or grounds. Use your own dedicated connection and you shouldn't have any problems. A good idea is to use an area of steel that has a double layer of steel body panels welded togehter.
sparky
oscarnl86
Copper - Posts: 84
Posted: August 25, 2006 at 9:00 PM / IP Logged
see i told you ask nousername or sparkie they know more than me 2001 malibu amp ground -- posted image.
(not trying to be rude j/k)
Monday, November 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
