2007 Toyota Camry, Speed Sense
hybridamp
Member - Posts: 29
Posted: August 27, 2006 at 12:50 AM / IP Logged
Where is the Speed Sense wire/tap located at on the 2007 Toyota Camry?
KarTuneMan
Platinum - Posts: 7,056
Posted: August 27, 2006 at 8:14 AM / IP Logged
Violet, in the radio harness
hybridamp
Member - Posts: 29
Posted: August 27, 2006 at 11:13 AM / IP Logged
Wow, that's the easiest location I've seen a manufacturer place the speedsense wire yet. lol
Thanks! 2007 Toyota Camry, Speed Sense -- posted image.
hybridamp
Member - Posts: 29
Posted: September 05, 2006 at 9:39 PM / IP Logged
Just a note, it is not in the radio harness if your vehicle does NOT come with the navigation system stock.
I'm still trying to find another location where the VSS might be located...
KarTuneMan
Posted: September 06, 2006 at 12:22 AM / IP Logged
So the wire is NOT there...you checked? You can have the Nav installed after you buy the car....doesn't make sence...
hybridamp
Member - Posts: 29
Posted: September 06, 2006 at 12:33 AM / IP Logged
Actually, I figured it out:
If you have the JBL premium system, but no factory nav, the speed wire (violet) feeds directly into the amplifier which is located under the center-console.
If you have a non-JBL system, but no factory nav, the speed wire (violet) is in the radio wiring harness.  The reason it's there is for the speed controled automatic volume leveler (as you speed up, the stock system raises the volume automatically).
So you were right, it's just in a different location if the JBL premium amp is present in the system. :)
KarTuneMan
Posted: September 06, 2006 at 1:02 AM / IP Logged
Kool man....good work gettin the info posted too!
