05 Impala, 2nd Acc
kgerry
Platinum - Posts: 3,455
Posted: August 30, 2006 at 9:30 AM / IP Logged
i have varying info here... anyone know if the Brown 2nd Acc MUST be hooked up for R/S?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
sparkie
Platinum - Posts: 2,061
Posted: August 30, 2006 at 10:16 AM / IP Logged
It doesn't need to be hooked up. There is a green second ignition wire that does though. You must also only use the light blue wire in the headlight switch harness to trigger the parking lights. It is a negative trigger circuit.
sparky
Thursday, November 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
