2005 Nissan Altima, Viper 791xv
jones100001
Member - Posts: 42
Posted: September 04, 2006 at 12:35 PM / IP Logged
Trying to install RS.  Do I need to hook up "neutral safety input"?  If so, where?
actionjackson
Copper - Posts: 59
Posted: September 04, 2006 at 12:55 PM / IP Logged
The viper 791 comes with a toggle switch with two wires on the back, ground one wire and hook the other wire up to the neutral safety wire
Jamie Jackson
*CRIMPING AINT EASY*
jones100001
Member - Posts: 42
Posted: September 04, 2006 at 1:17 PM / IP Logged
where would I find the neutral safety wire on a 05 Altima?
jones100001
Member - Posts: 42
Posted: September 04, 2006 at 9:10 PM / IP Logged
Anyone?
JWorm
Platinum - Posts: 2,208
Posted: September 04, 2006 at 10:13 PM / IP Logged
I would have to guess that less than 1% of installs have the neutral safety wire of the car tied into the remote start. Hook the wire up to one wire of the switch, hook the other wire up to ground. If switch is ON remote start will work, if switch is OFF it won't. Its that simple.
If you have a manual transmission...things change. Then you would want to tie into the neutral sensing wire at the ECU.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 04, 2006 at 10:19 PM / IP Logged
This will be his next question...."where is the neutral sensing wire?"
KarTuneMan
Posted: September 04, 2006 at 10:32 PM / IP Logged
JWorm
Posted: September 04, 2006 at 10:33 PM / IP Logged
Very few Altima's are manual transmissions. I wasn't going to go into details unless he needs the info.
Monday, December 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
