2001 grand am trunk wiring
gsx1000r02
Posted: September 13, 2006 at 11:47 AM / IP Logged
I have a 2001 Pontiac Grand Am. I am having problems with the trunk openning on its own. I have looked at the switch on the door and the one at the trunk, without any luck. I need the wiring diagram from the door switch back to the relay and back to the trunk to try and find out where I am getting and sending power. For some reason I think that I am ground the trunk latch in the harness and causing the trunk to open. Or, I have a computer related problem causing this issue. Thanx for any help that you guys can give me.
Platinum - Posts: 12,488
Posted: September 14, 2006 at 9:00 AM / IP Logged
Start troubleshooting at the switch and remove the switch out of the loop. If the problem persists, then it's either a wire issue or a computer issue.
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
