how to hide wires
kidwithaplan
Posted: September 22, 2006 at 2:54 PM / IP Logged
Ok, so i am on the bondo stage and i tested fitted everything and i relized that i didn't do anyhting to try and hid my wires on my amp so they are just kinda out there. Is there anyway i could hide the wires or make them look better there? Well if anyone got any type of suggestion or idea hit me with them i cna use jsuta bout anything thanks.
pic: [IMG]https://img.photobucket.com/albums/v200/BurningMaverick/P1010017.jpg[/IMG]
Custom_Jim
Copper - Posts: 210
Posted: September 22, 2006 at 3:26 PM / IP Logged
Get some spacer tubes to raise the amp off of it's mounting surface using some longer screws then get some 1" or whatever size PVC pipe that all of your wires can run through and directly in the center of the area underneath where the amp is at make a hole in the box to match the size of the PVC tube and then on the opposite wall make another hole and then slide the PVC tube through the center of the enclosure. Seal up the ends of the tube to the enclosure and then cut and sand down the tube flush to it's surface. Now run your wires through them. Where they come out under the amp route them to the amps terminals and have them fold under.
Jim
1968 Chevy II Nova Garage Find 2012
1973 Nova Custom
1974 Spirit of America Nova
1973 Nova Pro-Street
kidwithaplan
Posted: September 22, 2006 at 4:41 PM / IP Logged
That might work but under the amp is like a seperate scealed box and all and i have no access to it lol but it might still work though not a bad idea at all, it was my fault for not thinking about this before i started.
bellsracer
Silver - Posts: 703
Posted: September 22, 2006 at 11:14 PM / IP Logged
You can also make an amp surround that can hide the wires in it and give the amp a frame that will compliment the install.
kidwithaplan
Posted: September 23, 2006 at 6:56 PM / IP Logged
Waht exactly do u mean? sorry i am a lil out of it today i have been sanding the box all day, it is like 85 still here in AL, so if u don't mind coudl u give me some example of what ur talken about.
bellsracer
Silver - Posts: 703
Posted: September 24, 2006 at 12:37 PM / IP Logged
Something like this. Choice of materials and color are up to you. Consider 1/4" MDF with paint, or brushed metal.
how to hide wires - Last Post -- posted image.
crazyoldcougar
Copper - Posts: 185
Posted: September 25, 2006 at 8:56 PM / IP Logged
if it is a sealed emty chamber under the sub then you could just cut out the bottom of the box and then run the wires like it was mentioned...
Fiberglass Guru.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
