Car stereo / bulldog remote start 3-1
slacker2006
Posted: September 26, 2006 at 11:06 PM / IP Logged
I have a 2001 Sunfire and cant find a place to show me or tell me anythings on installing my car stereo because it is totally diffrent then all other makes as i am told have to have some sorta box for 250 in line for stereo to work and not screw anything up and another box for remote starter anyone have any ideas on this at all ?
any info would be great
thanks alot
Chuck
Drive it like you own it
xtremej
Gold - Posts: 1,440
Posted: September 27, 2006 at 7:48 AM / IP Logged
You will need either a digital interface metra part#GMRC-01 (the way I would go) or you can use the 70-2003-t harness in which the factory radio must be retained in the vehicle having a harness ran to this radio and back to the new one.
The remote start will require an ignition bypass as it is equipped with passwlock II. The best solution imo would be the gmbp from bypasskits.com. You'll find this bypass requires no cutting of the passlock wires therefore if it fails the vehicle will still start with the key. Just some advice if you plan on going through the work of installing a remote start I would suggest spending a few extra bucks and get something that is worth installing, bulldogs are very low quality units. Just my 2 cents.
Thursday, September 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
