Posted: October 09, 2006 at 3:28 PM / IP Logged
Posted: October 09, 2006 at 4:10 PM / IP Logged
Posted: October 10, 2006 at 1:57 AM / IP Logged
Posted: October 10, 2006 at 8:57 AM / IP Logged
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Rather than adding additional switches to actuate the door locks from the inside I would like to use the sliders in the doors.
The actuators have built in toggle switches which I would like to use to actuate the OEM relays. The problem is that these toggle switches will create a continuous signal to the relay....which is obviously not good. I was thinking if I could use the second toggle switch on the other side to deactivate that signal.....but at that point my brain starts to smoke ;-)
Ideally the signal would only be cancelled 0.5sec after the signal to complete the stroke of the actuator.
The truck is a 2005 Sierra base model without the door modules.
along with the relay in that picture.
Since I would like to use the auto lock/unlock feature AND want the install to look like OEM I would prefer to use the OEM relays.
