4 prong relay
Blt79
Member - Posts: 13
Posted: October 25, 2006 at 6:47 PM / IP Logged
I have a keyless entry system with relays on board in my truck. I just added a remote start system but the lock/unlock function will not tie into the keyless entry system. I can wire a relay for the RS system lock/unlock, but I can only get 4 prong relays in the small town that I live in. My problem is I don't know how to properly wire a four prong relay.
Blt79
Member - Posts: 13
Posted: October 25, 2006 at 7:02 PM / IP Logged
So wiring for a 2 wire aftermarket door lock actuators using a four prong relay is what I'm looking for.
sparkie
Platinum - Posts: 2,061
Posted: October 25, 2006 at 7:42 PM / IP Logged
It can't be done. You must get the correct relays.
sparky
hotwaterwizard
Silver - Posts: 1,350
Posted: October 26, 2006 at 11:49 PM / IP Logged
why can't it be done?
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
cntrylvr79
Silver - Posts: 582
Posted: October 27, 2006 at 8:43 AM / IP Logged
Because you can't 5 wire a door lock actuator with a 4 wire relay/
Cause I'm So white and nerdy...
First Class Certi-fried installer
hotwaterwizard
Posted: October 27, 2006 at 10:27 PM / IP Logged
Who said anything about a 5 wire setup?
Stockton California
master5
Silver - Posts: 1,123
Posted: October 27, 2006 at 11:01 PM / IP Logged
Another term for wiring an actuator to relays can be called a 5 wire setup, but realistically it is known as a (reversing polarity).
Basically, you need reverse the polarity on the actuator wires to get them to move up or down. A 4 prong relay is missing the center terminal (87a). That terminal needs to be grounded (-). with a 4 prong to can only send positive or negative depending, but not both...and you need both to get the actuator to move back and forth.
The 4 prong you have is typically used for switching or boosting only, like for a fog light switch were you only need to send a + or - signal. You can not make a 4 prong relay send both.
So you will need to find some 5 prong relays (you need 2) or a doorlock relay module.
Sorry, take care.
hotwaterwizard
Posted: October 27, 2006 at 11:40 PM / IP Logged
You are right I get it now.
4 prong relay -- posted image.
Stockton California
master5
Posted: October 27, 2006 at 11:46 PM / IP Logged
Yep..I count "5" on each..  lol
Nice diagram.
hotwaterwizard
Posted: October 28, 2006 at 1:27 AM / IP Logged
All of them are used too! I count 10 on the relays combined.
If I had more fingers I could count even higher!     4 prong relay -- posted image.
Stockton California
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
