first time help?
Rob20
Posted: January 23, 2003 at 9:11 AM / IP Logged
I've been interested in building fiberglass sub' enclosures for a while but never knew the steps. My question is can anyone tell me some general materials that are basic to use?
Also can anyone tell me general steps to building enclosures?
Pics would be a big help!
thanx, I'll be very greatful
Robert P.
Nick Johnson
Member - Posts: 9
Posted: January 23, 2003 at 8:34 PM / IP Logged
Robert,
Check out this website, www.carstereo.com.  They have step by step instructions on "how to" build practicaly anything out of fiberglass.
Nick (Dynamic)
Nick Johnson
audiomechanic
Silver - Posts: 388
Posted: January 25, 2003 at 6:09 AM / IP Logged
there is also another forum with pics and advice that is dedicated to all things fiberglass..... http://groups.yahoo.com/group/glassmanscustomforum
it has how to pick on various different cars and trucks doing different fiberglass projects, from doors, to consoles, to sub boxes..... there are tips on how to save money on larger jobs and time saving tips as well....installguy509
SuperChild5
Posted: February 12, 2003 at 4:18 PM / IP Logged
Robert;
Maybe you have heard of using polar fleece as an alternative to glass matt.  Fleece is easier to work with and if your mixture of resin and MEKP is correct the finished product is much easier to sand as well.  Also you could try mixing one batch of resin and MEKP and apply that and while the matierial is still wet mix and apply a batch of half bondo (polyester based) and resin with some MEKP and let it dry.  The second layer of Bondo/resin will not only add strength but it will also render your project easier to sand and get smooth.  Stretch the fleece over a rigid structure like MDF and glue or staple it to the back, (make sure to create and mount some speaker rings under the fleece with hot glue and backstrap).  Then proceed to resin it then resin/ bondo mix.  I was tought this technique by my instructors at Mobile Dynamics so this method has been prooven, plus it will be an easy first step into the world of fiberglass.  Good luck!!!!
Kieran
Mobile Dynamics Graduate
Future Shop/ Best Buy
