2004 Ford F450 Diesel
dereck
Member - Posts: 28
Posted: November 01, 2006 at 7:15 PM / IP Logged
Looking for wiring info for a 2004 Ford F450 Diesel, for remote starter instalation. Thanks
Twelvoltz
Platinum - Posts: 2,384
Posted: November 01, 2006 at 9:06 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES SUPER DUTY / 2004 / Remote Start
[PRINT THIS PAGE]
12volts      yellow & lt. GREEN/ purple       +       ignition harness
Starter      green       +       ignition harness
Second Starter      N/A
Ignition      RED / lt. green or WHITE/ yellow       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      gray / YELLOW & RED / black       +       ignition harness
Second Accessory      blue/lt. green       +       ignition harness
Keysense
Power Lock      see notes
Notes: Without keyless entry use pink / YELLOW for lock and pink/lt. green for unlock. They are 5 wire reverse polarity mastered from the driver switch and found in either kick panel. With keyless entry use WHITE/ red for lock and BLACK/ white for unlock. They are negative trigger and found at the VSM.
On the vehicles with keyless entry the GEM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Power Unlock      see power lock notes
Lock Motor      pink/black       5wi      VSM
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock Motor      RED / orange       5wi      VSM
Parking Lights+      brown       +       headlight switch
Parking Lights-      N/A
Hazards      same as turn signals
Turn Signal(L)      lt grn/wht (F), lt grn/org (R)      +       steering column
Turn Signal(R)      wht/lt blu (F), org/lt blu (R)      +       steering column
Reverse Light      BLACK/ pink       +       fuse box
Door Trigger      BLACK/ lt. blue       +       passenger kick panel
Dome Supervision      use door trigger
Trunk/Hatch Pin      N/A
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer      NOT RED / lt. green       ac       any ignition coil
Notes: On diesel vehicles the tach wire is GREEN / WHITE in a 5 wire harness held up with white tape behind the parking brake release.
Wait to start      see DirectFax document 1091
Notes: On the remote start, make sure to program the Accessory State During Wait To Start to ON.
Brake Wire      lt. green       +       brake pedal switch
Parking Brake      lt. GREEN/ red       -       parking brake switch
Horn Trigger      blue       -       steering column or VSM
Memory Seat 1      BROWN / lt. green       -       memory mod under dr seat
Memory Seat 2      BLACK/ orange       -       memory mod under dr seat
Memory Seat 3      N/A       -
Interface Module:      Category:
Immobilizer Bypass      Required:
No      Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
dereck
Member - Posts: 28
Posted: November 02, 2006 at 5:32 PM / IP Logged
Thanks, now the wait to start, what wire is that or how do i get DirectFax document 1091?
Twelvoltz
Posted: November 02, 2006 at 6:03 PM / IP Logged
1091 is a diagram of how to use a 528T, which is just a pulse timer. Just check your installation manual and see if it has a diesel mode, all of the new DEI product (atleast what I have seen) has a menu programmable option to delay the starter for a preset amount of time. What is the make and model of your starter?
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
