valet 712t into a 2004 dodge truck
wardyl
Member - Posts: 14
Posted: November 05, 2006 at 5:16 PM / IP Logged
I just installed a new starter in my 98 Expedition, due to failure. When i changed this out I had to disconnect the battery. Since I have done this the DEI Valet 561r starter isn't working do i need to relearn the transmitter like original. Or is there something wrong with my remote start?
Warren
brucewayne
Member - Posts: 7
2004 dodge truck
single wire system (ground - )
I have never installed a internal relay setup
I need a ground output for both lock and unlock.  I already have the proper resistor setup to work just need to figure out the alarm output.....
the lock common output 30, lock nor closed 87, lock open 87(input) ; where do they go
unlock 30 common output, unlock 87 nor open 87 input ; where do they go
thanks in advance, I cant figure this out
Peter
Twelvoltz
Platinum - Posts: 2,384
Posted: November 05, 2006 at 5:20 PM / IP Logged
Ward, did you make sure to ground the BLACK/ white wire on the DEI piece? This wire is a neutral safety wire which is not needed on your Expedition. If this wire does not see a ground the starter will not engage.
BruceWayne, you need to start your own thread...do that and someone will answer.
brucewayne
Member - Posts: 7
do i wire the purple (87 normally open)to a ground and then the unlock/lock 30 to the unlock /lock wire
brucewayne
Member - Posts: 7
Posted: November 05, 2006 at 5:23 PM / IP Logged
I did the title of this thread says dodge truck in it???? I dont know how the expedition post got in there
brucewayne
Member - Posts: 7
Posted: November 05, 2006 at 5:52 PM / IP Logged
figured it out, using the other posts in this forum WOOHOO
Twelvoltz
Posted: November 05, 2006 at 7:01 PM / IP Logged
That is odd, must have been a glitch with the site.
Glad to hear you got it working!
