Bridging amp
TruckFan
Posted: January 26, 2003 at 12:56 PM / IP Logged
Hi, i just installed a 25 x 4 RMS amp to push my infinity 5 x 7's. It seems as if the speakers are requiring more power. If i bridge the amp and run the speakers in parallel then that would drop the amp to 2 ohms and give me twice as much power to each speaker right? Any input is appreciated. Thanks Guys
Platinum - Posts: 12,488
Posted: January 26, 2003 at 6:33 PM / IP Logged
Yes this is correct but you will loose your left right balance.
zargon
Copper - Posts: 186
Posted: January 27, 2003 at 7:31 PM / IP Logged
bridge one 5x7 to each side of the amp many amps will bridge and only use the left input to run , if this is the case you will keep your left to right balance.
zargon ruler of estranorth
