prostart, 93 ford escort
dlambe
Copper - Posts: 57
Posted: November 24, 2006 at 9:24 PM / IP Logged
K guys I want to see who can help me out with this one, before I get started some background info;
1) car; 93 lx, 5 spd, basic deal (no cruise, a/c, alarm, wtc. just the basic car)
2)I am a heavy equipment tech and a wiring guru at work.
Now I bought a ct3260 remote starter from crappy tire and installed it, I have checked all the wiring 3 times for faults and or mistakes, I found none. The problem comes when I attempt to program this POS. I flash the hood pin as per normal and that works fine, however it will not accept the transmitter code, the park lights do come on but stay on solid they do not flash 5 times as per the instructions. I need help here guys its -20 celsius and I want to get this damn thing workin right. I tried both methods of programming it and neither worked, I have even reset the damn thing to no avail. The site for it is at www.prostart.org I am stumped any help would be appreciated. It does all the other functions bang on as well (ie, reset, valet mode, etc...)
dea,can
Copper - Posts: 284
Posted: November 25, 2006 at 1:38 AM / IP Logged
i have done a few of them  they are the same as the  autostrat line same brand  u sure u are not bring up the events playback mode have u tryed the assistance button on the module  its a little tricky if have not done  a few then its a snap you say you flash the hood pin and that works fine how long do you hold down the lock button  i had some take longer then usual also may have a faulty module
dragon
dlambe
Copper - Posts: 57
Posted: November 25, 2006 at 10:00 AM / IP Logged
I flash the hood pin by pressing it down for 4 seconds then letting go and quiclky pushing it down and releasing, then I turn the key on and off then I hold the lock button down for like 15 seconds at least. After about 3 seconds the park licghts come on and stay on for about 20 seconds. I have used the pab do do this as well to see if that worked.
dea,can
Copper - Posts: 284
Posted: November 25, 2006 at 12:40 PM / IP Logged
sure u have the right ignition wire hooked up  try programmming tach
dragon
dea,can
Copper - Posts: 284
Posted: November 25, 2006 at 12:49 PM / IP Logged
when u release the pin the second time you have snap the pin fast  so when you press it down the first time then the second time dont press and hold  like i said you need to snap it fast  press hold let go and snap second time.
dragon
dlambe
Copper - Posts: 57
Posted: November 25, 2006 at 4:32 PM / IP Logged
ok I went back to canadian tire and got a new one to replace the one I had, worked nicely, I programmed the remote and it recieves the signal no problem. Now this is where it gets confusing, can someone run down the process with me from the step after programming the remote, since when I did the tach programming I noticed that the park brake had to be disengaged for it to work for tach programming. I got to the step that takes you to idle mode but after I press button 2 when I am out of the vehicle and it shuts down the vehicle does not start again when I press button 2.
dlambe
Copper - Posts: 57
Posted: November 25, 2006 at 4:33 PM / IP Logged
also is it necessary for me to go into programming mode with this model?
dea,can
Copper - Posts: 284
Posted: November 26, 2006 at 1:16 AM / IP Logged
park lights flash,
dragon
dlambe
Copper - Posts: 57
Posted: November 26, 2006 at 10:24 AM / IP Logged
no after the vehicle shuts down when I press button 2 for idle mode there is nothing no park lights flash, however when I press 1 the lights do flash, 3 times when press it once and 2 times if I press it a 2nd time.
dea,can
Copper - Posts: 284
Posted: November 26, 2006 at 2:17 PM / IP Logged
so u can get it in ready mode ,all doors closed ebrake on press start button car stays running get out of car shut down car by remote  push start button car start  then if dont start do the events play back count the flashes look in book to see whats happen.
dragon
