10gauge cable to a Alpine amp MRV-F340
Roman
Member - Posts: 46
Posted: January 26, 2003 at 3:51 PM / IP Logged
Is it ok to use this cable(10gauge) to power amp MRV-F340(Alpine?
Thank you.
/ / / / / ALPINE
themagicone
Silver - Posts: 325
Posted: January 26, 2003 at 5:13 PM / IP Logged
I wouldnt do 10gauge for any amp, go with 8 at least.
fakepete
Copper - Posts: 99
Posted: January 26, 2003 at 5:21 PM / IP Logged
I would go with a 4ga or even 2ga.  Its overkill, but you'll have no problems with voltage drop and if you ever upgrade your amp you won't have to replace the power wire.
Platinum - Posts: 12,488
Posted: January 26, 2003 at 5:31 PM / IP Logged
With 4 or 2 gauge you will need a distribution block or a reducer for the Alpine amp to support it's size. I would say go with 4 gauge into a distribution block and from there go 8 gauge to the amp from there. You have full upgrade options then with this method as well you can run multiple amps as well.
Roman
Member - Posts: 46
Posted: January 27, 2003 at 10:44 AM / IP Logged
Thank you.Does anyone know best place to put amps in A-class mercedes?
Thank you.
/ / / / / ALPINE
fakepete
Copper - Posts: 99
Posted: January 28, 2003 at 4:08 PM / IP Logged
Is that one of those real small hatchback types?  If so, I'd say anywhere you can fit an amp since it doen't seem like there's a whole lot of room in them.
Roman
Member - Posts: 46
Posted: January 28, 2003 at 4:43 PM / IP Logged
Thank you.
Yes it's realy smaal!Too small!(A- class mercedes)
/ / / / / ALPINE
5hift fast
Member - Posts: 19
Posted: January 29, 2003 at 9:42 AM / IP Logged
My alpine amp accepts 4 gauge power and ground cables.....
I would do 4 gauge
