Head Unit Noise
Wyotech21
Member - Posts: 7
Posted: December 06, 2006 at 6:43 PM / IP Logged
Hey Guys,
I'm gettting what seems to me as head unit noise. In cd mode I can hear the cd player loading the disc and spinning through the subs. The subs jump or react to those actions of my cd player. I thought maybe it was my amp ground so I changed it's location, still makes the noise. Power wire and rca's are not running together. I'm thinking maybe running a new ground for my headunit? Or getting new Rca cables. I believe my Rca cables run with my remote wire, would that cause this noise? Any and all help would be greatly appreciated
{{If you cant buy it, make it.}}
Platinum - Posts: 13,725
Posted: December 06, 2006 at 7:19 PM / IP Logged
       Let us guess     a   Pioneer deck?
cntrylvr79
Silver - Posts: 582
Posted: December 06, 2006 at 7:26 PM / IP Logged
Na I think it's a pioneer deck.  Which means probably blew an internal fuse on the rca wire.  Strange how they put a fuse INSIDE the radio that requires complete dissassembly to get at.
Cause I'm So white and nerdy...
First Class Certi-fried installer
Wyotech21
Member - Posts: 7
Posted: December 07, 2006 at 7:14 AM / IP Logged
Actually it's a Panasonic head unit. The music still plays, but when taking a cd out, putting a cd in, and while the cd is loading, all these noises can be heard through the subs.
DYohn
Platinum - Posts: 10,741
Posted: December 07, 2006 at 8:24 AM / IP Logged
Sounds like grounding issues.  Check the sticky posts.
forbidden
Platinum - Posts: 5,354
Posted: December 07, 2006 at 11:54 AM / IP Logged
Turn down the gain on the amp(s), reground the head unit. Sounds to me like there is a problem in the actual cd player itself. If you still have noise after this, try a different cd player.
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
