security bypass, 2007 jeep grand cherokee
taskforce
Posted: December 06, 2006 at 7:48 PM / IP Logged
looking for idea/s to create a system to allow this vehicle to run without the keys in it for longer than the standered time of 15-20 minutes like remote starters allow. this is a emergency vehicle and will be left unattended while running, looking for a minimuim run time of 45 minutes.  many on board components are tempature sensotivethis is a 2007 jeep grand cherokee, any ideas?
Task-Force lighting
rudydapimp
Copper - Posts: 390
Posted: December 06, 2006 at 8:51 PM / IP Logged
well, I know that my avital 4100 will run until you turn it off. selectable 12, 24 60 min and Run. also, many have a timer mode that will start at three hour intervals to worm up truck. and some will start if vehicle get to a certain temp.
CruisinS&S
Copper - Posts: 225
Posted: December 06, 2006 at 8:53 PM / IP Logged
All DEI units (viper, valet, hornet, avital, etc.) have a run time of 60 minutes if you want.
Cruisin Security And Sounds
tragik
Copper - Posts: 169
Posted: December 06, 2006 at 9:25 PM / IP Logged
you could use a latching relay to keep the ignition and accessory wires powered after the runtime expires. In theory, you could have it run forever.
Scytek units can be programmed for a runtime of upto 255 minutes if you have the wizard programmer.
Northstart.....or start it your damn self.
Hymer
Silver - Posts: 695
Posted: December 07, 2006 at 2:02 PM / IP Logged
I think a 1kohm resistor to ground will do this.. not entirly sure.    if the mux wire sees it it thinks the key is still in the ign and wont shut off.... the best thing would be to put a rs in it.. set for continouse mode or 60 min.. call bypasskits.com tech support and tell the tech what you want to do, he's pretty good on the resistor valus that chrysler products need to see in order for them to functioin right [or wrong as this case is]
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
