ford focus 05 wiring
mike08401
Member - Posts: 33
Posted: December 10, 2006 at 9:41 PM / IP Logged
I need alarm and auto start wiring diagram for my aunt 2005 Ford Focus SE
Please help if you got one
Thank youford focus 05 wiring - Last Post -- posted image.
spookiestylez
Silver - Posts: 531
Posted: December 10, 2006 at 9:44 PM / IP Logged
12volts      red (30A)       +       ignition harness
Starter      gray/black       +       ignition harness
Second Starter      N/A
Ignition      GREEN/ YELLOW       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      yellow       +       ignition harness
Second Accessory      N/A
Keysense      RED / black       +       ign harness or GEM, tan plug, pin 8
Notes: The GEM (Generic Electronic Module) is above the passenger kick panel.
Power Lock      BLACK/ red       -       driver kick or GEM, gry plug, pin 15
Power Unlock      BLACK / YELLOW       -       driver kick or GEM, gry plug, pin 21
Lock Motor      yellow/black       5wi      driver kick or GEM, grn plug, pin 3
Unlock Motor      WHITE/ black       5wi      driver kick or GEM, brn plug, pin 5
Parking Lights+      orange / YELLOW       +       switch or GEM, tan plug, pin 14
Parking Lights-      N/A
Hazards      BLACK/ orange       -       switch or GEM, tan plug, pin 23
Turn Signal(L)      blue/white (F), blue (R)       +       GEM, blu plg, pin 4; gry plg, pin 2
Turn Signal(R)      blue/red (F), blue/red (R)       +       GEM, blu plg, pin 3; grn plg, pin 4
Reverse Light      GREEN/ black       +       driver kick, harness to rear
Door Trigger      see notes       -       GEM
Notes: The LF door is BLACK / YELLOW in the tan plug, pin 22. The RF door is BLACK/ blue in the tan plug, pin 21. The LR door is BLACK/ orange in the green plug, pin 15. The RR door is BLACK/ green in the gray plug, pin 18. Use all four wires and diode isolate each.
Dome Supervision      BLACK/ blue       -       dr A pillar or GEM, gry plug, pin 3
Trunk/Hatch Pin      BLACK/ blue or BLACK / YELLOW       -       light in trunk/cargo area
Hood Pin      BLACK / YELLOW       -       pin switch or GEM, blu plug, pin 21
Trunk/Hatch Release      BLACK / YELLOW       -       switch or GEM, brn plug, pin 16
The trunk/hatch release motor wire is WHITE/ green (+) in the driver kick or GEM, green plug, pin 2.
Power Sliding Door      N/A
Factory Alarm Arm      BLACK/ blue       -       driver kick or GEM, gry plug, pin 16
Factory Alarm Disarm      BLACK/ white       -       driver kick or GEM, gry plug, pin 14
Disarm No Unlock      see factory alarm disarm
Tachometer      BLACK/ stripe       ac       any fuel injector
Wait to start      N/A
Brake Wire      GREEN/ red to GREEN/ YELLOW       +       switch or GEM, tan plug, pin 9
Parking Brake      BLACK/ red       -       parking brake switch
Horn Trigger      BLACK/ blue or BLACK/ green       -       switch or GEM, brn plug, pin 14
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
SecuriLock
Part #: 1100F
Alternate Part1 #: 555SW
Alternate Part2 #: 556UW
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Alternate Part5 #: 1100X
Notes: Standard on all models. When using the 1100X, a software change to 1100FM is needed.
Smart Starter Kill Relays:      Relay Type:
Eng. Management Relay      Location:
Engine compartment fusebox, Driver side, #8
Part #: 6413A
rtfm
Tuesday, May 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
