Can excessive LEDs cause a dead battery?
skunk0526
Member - Posts: 33
Posted: December 13, 2006 at 10:17 AM / IP Logged
I installed 2 additional LEDs in my 2000 civic awhile back. One in each door. This my be completely unrelated but recently the battery seems to die after sitting for a day or so without starting. I know the leds only draw like a half an amp each, but i cant attribute the problem to anything else since the battery is only 2 months old. My amps turn off with the car, and the LEDs are the only thing drawing with the car off. Alternator problem maybe?
2000 Honda Civic 4DR
Alpine 7892 HU
PPI A404.4 [HP] w/.5F Cap.
PPI A600.2 [LP] w/1F Cap.
Infinity Kappa 3-way 6.5"
Infinity Kappa 6x9
Infinity Kappa 4OHM DVC
VT Slot Port Box
Dynamat rules
mobilecustoms
Silver - Posts: 397
Posted: December 13, 2006 at 10:23 AM / IP Logged
possible that if you have a lot of leds. how many total do you have? try to see the drain on the battery with a dmm
KPierson
Platinum - Posts: 3,527
Posted: December 13, 2006 at 12:46 PM / IP Logged
1/2A a piece?????  That would be 1A total, and definately considered an excessive draw.
Kevin Pierson
spookiestylez
Silver - Posts: 531
Posted: December 13, 2006 at 12:52 PM / IP Logged
disconnect the leds and then leave the car for a few days and see if it still does it, process of elimination. What kind of leds are you using??? most leds only require 200mA
rtfm
KPierson
Posted: December 13, 2006 at 1:17 PM / IP Logged
I've never seen an LED pull 200mA either.  The superbright LEDs I use draw < 30mA and are blinding.
A 'normal' led should draw less then 10mA or so when on constantly.
Kevin Pierson
splaudio
Copper - Posts: 237
Posted: December 13, 2006 at 6:52 PM / IP Logged
just a .5amp for several days of draining and doing this several times will wear a battery down...
brhaugen
Copper - Posts: 275
Posted: December 13, 2006 at 9:09 PM / IP Logged
Might be time for a new battery?
camarov6beast
Posted: December 14, 2006 at 10:31 AM / IP Logged
leds only draw 20mA, i work with LEDs, i can make you anything you need in the world of LEDs, just let me know at   MICHAELtheLEDguy@gmail.com
