PKF2 Problem in Focus
oakley2000sel
Member - Posts: 33
Posted: January 02, 2007 at 9:12 PM / IP Logged
Ok got it to finally work! I followed all the instructions on here and the manual with no results. Everytime I turned the first key and second key on and waited for the light to turn off it was ok. It's when I got to jumping the ign wire and grounding the brown wire and waited for the LED to turn off the security light would start flashing rapidly. I tried everything until I tried: First Key 1 sec then second key 1 sec and then jumped the ign wire 1 sec. Never waited for the LED to turn off. Started the car with key then tried remote starting and Vrooom Vroooom! Yay! Thanks for all your help and quick responses as usual. Hope this will help others in the future.
john ogrady
Copper - Posts: 82
Posted: January 05, 2007 at 7:32 PM / IP Logged
When I program these modules I watch the PATS led on the dashboard Insert first key turn to on position wait for led to go out.Insert second key turn to on wait for led to go out.remove key try remote start If it works the vehicle will start.The brown I already have hooked up to the remote start.This way has worked well for me.
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
