1996 chrylser lhs, alarm/remote start
shredder130
Member - Posts: 41
Posted: January 07, 2007 at 6:25 AM / IP Logged
hi
    i have a 1996 chrysler lhs and i would like to install my ScyTek galaxy 5000rs-2w plus 2 way paging alarm/remote start. i don't know how to install it because of the factory alarm on the car. do i have to use the car's door unlock wire as a factory alarm disarm ?
i also don't know what to do about the ignition 3 (air bag) light wire
any help would be greatly appreciated
shredder130
Member - Posts: 41
Posted: January 07, 2007 at 6:40 AM / IP Logged
here is a link to scytek's alarm manuals http://www.scytek.net/company_pdf_manuals.html
KarTuneMan
Platinum - Posts: 7,056
Posted: January 07, 2007 at 9:02 AM / IP Logged
Your lock wires (with proper resitors installed) will control the factroy security system.
2 ign. NOT 3.
1 dk.blue  2 RED / wht.
Stay away from the yellow harnesses, or the harnesses wrapped in yellow tubing.
shredder130
Member - Posts: 41
Posted: January 07, 2007 at 9:49 AM / IP Logged
so i don't have to connect the air bag light one, i was confused because of the guide on here lists it
Constant 12V+     Pink/Black        Ignition Switch Harness
Starter      Yellow/Gold      Ignition Switch Harness
Ignition      Dark Blue      Ignition Switch Harness
Ignition 2      RED / White 12GA      Ignition Switch Harness
Ignition 3      RED / White 18GA      Ignition Switch Harness (Air Bag Light)
Accessory      BLACK/ Orange      Ignition Switch Harness (Heat/AC)
Tach      Red      WHITE/ Black (PCM Passenger's Wheel Well 2 Cylinder Setting)
Neutral Safety Wire      BLACK/ Light Green      Switch on Driver's Side or Transaxle
Brake Switch      White or WHITE/ Tan      Brake Switch
Trunk Release      BLACK/ White (+)      Switch in Glove Compartment
Trunk Pin      BROWN / Black (-)      Driver's Kick Panel
Parking Lights      BLACK / YELLOW      Driver's Kick Panel
Head Lamp      Green      Light Switch
Hood Pin      n/a
Factory Disarm      Light GREEN/ Orange (-)      High Driver's Kick Panel
Door Trigger      Yellow (-)      Driver's Kick Panel White 20 Pin Connector
Door Lock      ORANGE / White      Behind Fuse Panel at Door Lock Relays
Door Unlock      Pink/Purple      Positive Trigger
Horn Wire      BLACK/ Red (-)      Horn Relay in Fuse Panel
Windows Up      LF=Light Blue/Gold, RF=BROWN / White, LR=Blue/White, RR=Gray/Black
Windows Down      LF=WHITE/ Gold, RF=PURPLE / White, LR=RED / Black, RR=GREEN / WHITE
shredder130
Member - Posts: 41
Posted: January 07, 2007 at 9:52 AM / IP Logged
oh and how would i do the door lock wiring, i just ordered 4 relays, a dual relay pre-wired block and two prewired relay blocks from parts express today
shredder130
Member - Posts: 41
Posted: January 08, 2007 at 5:41 PM / IP Logged
ttt
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
