Ebay GV9 Alarm Problem
red91sit
Posted: January 10, 2007 at 11:45 PM / IP Logged
I have recently installed a GV9 (noname) remotestart/alarm in my car.  The problem is when I connect the LED's stay stuck on, and well it doens't work at all.  The remote seems fine, it shows the little "no reception" icon, but the car leds (one normal blinking one, and 2 on the valet switch/antenna) stay on.  I tried reprogramming the remotes, but they still did not detect the car, so i tried to reprogram the alarm system, but it doesn't seem to respond.  When I push the vallet button the leds get slightly brighter, but nothing else seems to happen.  I tried unplugging different things, like the led, the power locks, etc. and as long as the brain has power and ground, the vallet lights stayed on Ebay GV9 Alarm Problem -- posted image.
Could it be a bad brain unit?
mikvot
Gold - Posts: 1,043
Posted: January 10, 2007 at 11:55 PM / IP Logged
possibly....are u sure u have a true ground?
red91sit
Posted: January 11, 2007 at 12:08 AM / IP Logged
I think so?  It's a bolt on the frame, when i disconnect the wire the lights turn off.  It only has one ground as well.  I just tried changing it to a direct grounding wire to the battery, same result Ebay GV9 Alarm Problem -- posted image.
mikvot
Gold - Posts: 1,043
Posted: January 11, 2007 at 12:12 AM / IP Logged
it could be a bad brain... if u have time post the wiring for the system, and tell me what vehicle u are putting it in. i'll try to help out as much as i can.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 11, 2007 at 12:22 AM / IP Logged
My advice to you, is to never again buy any electronics off of E-Bay..... I cannot tell you the horror stories a guy my age has heard. And I'm not even that old....
ers1121
Copper - Posts: 110
Posted: January 11, 2007 at 4:09 AM / IP Logged
I agree with KarTuneMan, buying off of Ebay is risky. But if you are going to buy there at least buy a name brand product. I admit I have purchased a lot of R/S systems there before getting my local supplier and I only bought the major brands and never had I problem.
Good luck,
Ed
Ed
red91sit
Posted: January 11, 2007 at 8:22 AM / IP Logged
Yes, I've learned my Ebay lesson, the hard way for sure.
Anyways, I"m installing it into a 1995 Honda Civic Coupe.  I found the cars wiring diagrams off of several good sites, and they all matched up, so I'm not concerned with those.  Here is a link to the alarms wiring diagram.
http://www.freewebs.com/red91sit/wirigndiagram.jpg
alexlloyd
Member - Posts: 24
Posted: January 11, 2007 at 8:45 AM / IP Logged
Without the brand it is dificult to say but my predator requires the key on, engine off, foot on the brake in order to change the valet mode. Without all three met, the switch is just a nice toy that does nothing. Further, the system cannot program remotes while in valet mode.
alexlloyd
Member - Posts: 24
red91sit
Posted: January 11, 2007 at 7:11 PM / IP Logged
Well, good news, it's better :-) haha, the only bad part is, The only thing i did to fix it was go to school, i came home,and now it works??!! oh well thanks for all the help everyone!
