2003 Pontiac Bonneville Alarm/RS Wiring
Welcome Guest :)
jamez99
Member -
Posted: January 13, 2007 at 6:30 PM / IP Logged
I would like a wiring diagram for my 2003 Pontiac Bonneville to install a remote starter with immobiliaer/bypass. thanks.
KarTuneMan
Platinum -
Posted: January 14, 2007 at 12:55 PM / IP Logged
Wire/Function | Colour | Location/Description | Polarity |
PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
12 VOLTS | Red | at battery or behind fusepanel | + |
| | It is recommended that you find an alternate power source than the one from the ignition switch since this wire is a very small gauge. |
IGNITION | Pink | Ignition switch | + |
| | These wires are all small gauge but can be connected normally. |
IGNITION 2 | White | Ignition switch | + |
ACCESSORY | Orange | Ignition switch | + |
STARTER | Yellow | Ignition switch | + |
KEY SENSE | Lt.green | Ignition switch | - |
TACH SIGNAL | White | At coil pack on right side of engine | AC |
LOCK | RED / black | At switch in driver's door | - |
| | This is a multiplex doorlock system. You must run wires into the driver's door to interface the doorlocks. |
UNLOCK | ORANGE / black | At switch in driver's door | - |
DRIVER LOCK MOTOR | Gray | In driver's door at switch | + |
DRIVER UNLOCK MOTOR | Tan | In driver's door at switch | + |
PASSENGER UNLOCK MOTOR | Tan | In passenger door at switch | + |
DOORPIN | BLACK/ white | In each individual door | - |
DRIVER DOOR LATCH | Tan | 8-pin plug on driver's door module | - |
| | This is a multiplex system. You must go into the driver's door to interface these wires. Pulse a ground (-) to the TAN wire at the same time as lock to arm the factory alarm, diode isolate. |
FACTORY ARM | Tan | 8-pin plug on driver's door module | - |
FACTORY DISARM | Lt.green | 8-pin plug on driver's door module | - |
KarTuneMan
Platinum -
Posted: January 14, 2007 at 12:56 PM / IP Logged
BRAKESWITCH | White | At switch above brake pedal | + |
PARKLIGHTS | BROWN / white | At light switch harness | - |
HORN | Black | At steering column | - |
DRIVER WINDOW UP | Dk.blue | At switch in driver's door | REV POL |
DRIVER WINDOW DOWN | Brown | At switch in driver's door | REV POL |
PASSENGER WINDOW UP | Dk.blue | At switch in passenger door | REV POL |
PASSENGER WINDOW DOWN | Brown | At switch in passenger door | REV POL |
LEFT REAR WINDOW UP | Dk.blue | At switch in left rear door | REV POL |
LEFT REAR WINDOW DOWN | Brown | At switch in left rear door | REV POL |
RIGHT REAR WINDOW UP | Dk.blue | At switch in right rear door | REV POL |
RIGHT REAR WINDOW DOWN | Brown | At switch in right rear door | REV POL |
HEADLIGHTS | White | At steering column | - |
VSS WIRE | Dk.GREEN / WHITE | Cruise control module | AC |
DATABUS INTERFACE | Pin-2(top row from left) | Diagnostic plug below dash | DATA |
Saturday, May 4, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
