Diode to isolate radio?
brilliant25
Posted: January 14, 2007 at 1:57 AM / IP Logged
I just finished my Viper 1000 install.I used the acc. on after ignition is shut off to keep the radio powered up. I don't like that power feeds other circuits. What diode can I use to isolate the radio? Should I worry about the amp rating of the diode? Thanks!
KarTuneMan
Platinum - Posts: 7,056
Posted: January 14, 2007 at 9:05 AM / IP Logged
What kind of vehicle?
brilliant25
Posted: January 14, 2007 at 11:27 AM / IP Logged
1998 Subaru Impreza 2.5RS
KarTuneMan
Posted: January 14, 2007 at 12:26 PM / IP Logged
I don't understand what you are attempting to do.....and more importantly, why?
I'm sorry I don't get it.
brilliant25
Posted: January 14, 2007 at 12:50 PM / IP Logged
My alarm has a output channel that maintains power till a door is opened or alarm is armed. I connected this to my radio so it will stay powered till I get out of the car. The only down side is power back feeds into the rest of the circuits that are also on that side of the circuit. I wan't only to have the radio power up, so I would like to isolate the radio circuit.
brilliant25
Posted: January 14, 2007 at 1:34 PM / IP Logged
I got it. I had a diode sitting arond for a install a long time ago. I installed it on the factory harness wire that supply's 12volts to the radio with the key on. Then placed the alarm wire after the diode. Now only radio stay's powered up when the key is turned off.
profuse007
Gold - Posts: 2,015
Posted: January 14, 2007 at 2:40 PM / IP Logged
check out the relay section, "retaining accessories."
Houston,TX
Tuesday, February 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
