2000 GMC Sierra, Compustar
dirtydodge
Member - Posts: 22
Posted: January 14, 2007 at 2:37 PM / IP Logged
i pulled the unit out from my last attempt at installing it,...but here goes attempt number 2
i have a compustar 2wss-as remote start and alarm,..its the cm-3000 series
i have hooked up the main 8 wires of the harness
the remote page sensor
the antenna
the lcd
the siren
the tach sense wire to the white wire off the cluster
and the 2nd ign 200ma output (pin #3) to the wire on the prewired relay
i was told to get the remote start feature working before going through with the rest of the alarm, and when i press the button on the 2 way remote,. the unit powers up, the dash lights and headlamps come on and then nothing for about 10 minutes,..then the vehicle trys to start then dies.
heres what i have hooked up so far:
Compustar brain        truck
Red                  red   (constant 12+)
Gr/Wh     light blue at back of headlamp sw (12+ with switch on)
RED / Wh               red (constant 12+)
White               Orange (heater/Ac)
Violet               Prewired into starter kill relay
Yellow           i cut the yellow starter wire and the solid yellow is to the starter and the yellow black off the relay is going to the key side
Green               pink (12+ with key on)
Black               Grounded behind dash
i am just wondering if the 10 minute delay in the truck trying to start is from a wiring issue or if i got a bad brain from compustar,...any help is greatly appreciated
dirtydodge
Member - Posts: 22
Posted: January 14, 2007 at 2:38 PM / IP Logged
sorry i made a mistake on my topic,...its a 2000 GMC sierra
dirtydodge
Member - Posts: 22
Posted: January 14, 2007 at 2:40 PM / IP Logged
i have the relay hooked up to the white ign 2 wire on the truck as well,..forgot to add that in,...this is the same relay that the 200ma wire is hooked to
Moderator - Posts: 12,488
Posted: January 14, 2007 at 5:27 PM / IP Logged
You need to hook up a programmer to see what the delay start time is set to. I've had this happen to a few units where the delay timer on the unit would engage.
dirtydodge
Member - Posts: 22
Posted: January 14, 2007 at 10:27 PM / IP Logged
is that something that only dealers would have? the programmer i mean? or is it something i can check at home?
xtremej
Gold - Posts: 1,440
Posted: January 15, 2007 at 7:43 AM / IP Logged
I don't believe you can purchase the op-500. I think they are a dealer only item, but then again so is the compustar remote start line so who knows.
Posted: January 15, 2007 at 8:34 AM / IP Logged
Go back to where you bought the system so they can program the unit for you.
dirtydodge
Member - Posts: 22
Posted: January 15, 2007 at 8:05 PM / IP Logged
ok i went to the local compustar dealer and he hooked up the programmer to my unit and shut off all the options that came turned on,..
now i have the remote start workimg and tucked away nicely,...
i have found the door lock wires that pulse +12v when the switch is toggled,...but it doesnt seem like the compustar brain is sending out its signal,...do i need relays for the door locks?
i am using the white and light blue wire at the brown plug in the BCM each wire pulses respectively when lock or unlock is hit on the drivers switch,...but when hooked up to the brain it doesnt work,...and my multimeter doesnt show a pulse coming from the brain,...
is this something he could have mistakenly turned off with the programmer?
Posted: January 15, 2007 at 8:38 PM / IP Logged
The truck uses a (+) pulse and the Compustar has a (-) pulse. You will need to hook up relays or polarity inverter for the keyless entry to work.
dirtydodge
Member - Posts: 22
Posted: January 15, 2007 at 11:35 PM / IP Logged
thanks to everyone that helped out with info,...the whole thing is installed except for the door locks which i will get into on my next days off
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
