2005 Saturn Relay Remote Start
mrchevelle
Member - Posts: 11
Posted: January 15, 2007 at 2:30 PM / IP Logged
i did cut the red loop and its tach sense>>>Whats the plan???Thanks for help
mrchevelle
Big Dog
Gold - Posts: 1,265
Posted: January 15, 2007 at 2:40 PM / IP Logged
You sure lock signals coming from 570? Disconnect temporarily and test to be sure.
Prepare your future. It wasn't the lack of stones that killed the stone age.
mrchevelle
Member - Posts: 11
Posted: January 15, 2007 at 2:54 PM / IP Logged
lock/umlock  signal not coming from 570
mrchevelle
Big Dog
Gold - Posts: 1,265
Posted: January 15, 2007 at 3:00 PM / IP Logged
Do they lock/unlock when you turn the key to ignition then off?
mrchevelle
Member - Posts: 11
Posted: January 15, 2007 at 3:01 PM / IP Logged
yes, on lock, off unlock
mrchevelle
mrchevelle
Member - Posts: 11
Posted: January 15, 2007 at 3:02 PM / IP Logged
double checked no they dont lock till you start moving and dont unlock untill you remove the key
mrchevelle
Big Dog
Gold - Posts: 1,265
Posted: January 15, 2007 at 3:15 PM / IP Logged
I think you're trying to say that the 570 runs then when it shuts down then it unlocks.
If that's the case and what you just posted, then the vehicle's BCM is unlocking the doors when it sees ignition off.
Either re-program the car so it doesn't do this or connect the RAP disable GREEN/ black wire of the 570 (also must cut GREEN/ black loop) to the lock wire in the car (ORANGE / black, driver's kick, negative trigger). Hopefully you aren't using it for FAD.
mrchevelle
Member - Posts: 11
Posted: January 15, 2007 at 3:24 PM / IP Logged
it unlocks as soon as the remote start engages,  i do currently have the GREEN/ black wired to  FAD, re programming of the car? would that be done at a dealership? the locking/unlocking is easier to deal with than the 3 min run time do you have any suggestions for that???Thanks for all the help
mrchevelle
Big Dog
Gold - Posts: 1,265
Posted: January 15, 2007 at 3:36 PM / IP Logged
It seems like FAA is unlocking your doors.
Re-program: There might be info in the owner's manual how to remove ignition controlled door locks via the DIC (driver info center) - if customer is OK with it.
3 minute runtime? Haven't the foggiest since it isn't even a programming option. Try disconnecting/reconnecting the two fuses then reprogram TX's and TACH.
mrchevelle
Member - Posts: 11
Posted: January 15, 2007 at 6:52 PM / IP Logged
2005 saturn relay   remote start hornet 570t, runs, works, but  only runs for 3 minutes, the unit is factory programmed for 12 minute run time>>>>LOST???? Not sure whats going on its got onstar not sure if that has any say in the security>>>>Any Ideas???
mrchevelle
